New parts
13 Jun 2004
Brechin
Going to be buying new components proberly monday
As you can see im getting the Oc bundle as i dont have a clue about overclocking.
But whats the difference between the gigabyte board and the Asus P6X58D-E board.
Also not sure about the canned air, im thinking it will be safer using that than taking the antec 900 down to the shed and using a comperssor to clear all the dust out of the fans. Havent been cleaned for a while ( 1-2 years :eek: )
Ohh and just remembered will there be enough screws to do a push/pull on the h50 with the 2 Vipers or will i need to buy some?
Hi.
I don't have the H50 myself, but i believe you only get enough screws (they are not normal type fan screws) for one fan and people just use two screws for each fan.
If your just cleaning fans, i would just use a clean paint brush and a cloth.
