Ok firstly Hi, just signed up and these forums seem very informative in some areas.
Well i have decided to build my first PC as up to now i have had a friend build them then upgrade them myself. Everytime i have had a PC i have had a rubbish case which has lead to all sorts of overheating problems.
Now i have around £100 ideally on a case, however would be willing to go a bit higher if their is anything better than the Eclipse for slightly more?
Also does the Eclipse come with fans as i have been looking around and its a bit of a mixed opinion as to what i would actually have to buy to make the case complete.
As for everything else I am looking at getting this, so will the case be suitable?
> Intel Core 2 DUO E6600 "LGA775 Conroe" 2.40GHz
> Not sure on the MB yet, if anyone wants to reccommend one
> RAM 2-3GB (again not sure what RAM to get just now)
> 8800 GTX
> At least a 500 gb HDD
> One Optical Drive
> Dont have a clue on soundcards, but basically im looking for something that manages to produce a good sound, i currently have onboard so anything is an improvement!
> I will also be getting a 750 Watt PSU to be on the safe side.
I am not sure how much this will cost but last time i priced it up it was setting me back £1200 without the 8800 GTX.
It is also worth mentioning i am primarily buying this to do all my design work which involves extremely large image files so hence why the larger hdd is needed and also to play Crysis on, as i think my Atlantis Sapphire 9800pro wont quite manage that
, it struggles on everything now
Any help is appreciated, thanks
> 8800 GTX
> One Optical Drive
