New PC Advice
3 Oct 2006
The C2D would be straying towards the right direction :)
With that budget, do you need peripherals, a monitor, etc?
A little something to consider.
^ I'd get a bigger HD, and remove Vista for XP Home OEM...much cheaper and it'll do till Vista bugs are sorted out.
He'd need XP-64 if he wanted to address all of the RAM. That HDD is the fastest 7200.10 available. I chose it for a reason.
If you want a larger HDD the one to get is the 500 GB Western Digital AAKS.
