My computer is being rather erratic and freezing at the windows splash screen stage, where the progress bar stops and the computer stops responding. Very occasionally I can get through into windows, and when it does, the computer is perfectly stable.
I believe its a graphics card related problem, as when I built the computer, the graphics card drivers refused to install, and froze. I eventually got the drivers on after putting a newer bios on my motherboard, and it was fine for a while, but the problem has started again. The computer fails to load into windows maybe 7 times out of 8. If it is a graphics card problem, then it seems strange that when I get into windows, it easily handles heavy gaming, including oblivion, fear, farcry, half life 2 etc.
My computer specs are:
Antec p150
Asrock 775Dual-VSTA
Core2Duo E6300
1gb (512x2) Twinmos pc3200 DDR
74gb raptor
250gb seagate barracuda
Arctic cooling freezer 7
Gigabyte x800pro -> xt agp
What could this problem be, and how could I fix it? Its beginning to really fray my patience
Antec p150
Asrock 775Dual-VSTA
Core2Duo E6300
74gb raptor
