Hi
I got a new *Competitor PC!* a month ago, spec below.
It was all fine for the first couple of weeks but then I got a BSOD. I can't remember what I was doing but it was nothing special. A week later another, again not doing anything special. A few days ago, another while I was away from the computer and yesterday when I came back to the PC after a while the screensaver and the whole system had frozen solid.
It seems OK the rest of the time and I have had it on 24/7 since I installed it but surely that is cause for concern? I ran Memtest86+ last night to see if there was an issue with one of the RAM modules but after 12 cycles there were no errors detected.
Now if I had to guess I'd point the blame squarely at the SSD boot drive purely from the number of problems I've heard mentioned in passing. I took a risk when I went for a system with an SSD and I'm starting to think it was a bad idea.
So what I'm posting here for really is advice as to whether I should do some tests myself or just get in touch with *Competitor!* and get them to sort it. Also wondering whether to request a refund on the SSD and just get the O/S installed on a regular hard drive. If I should run tests then which ones and links please!
Basic Specification:
Fractal Design R3 Case in Black
2 manually RPM-controllable Fractal Design ultra-low noise case fans
Intel Core i5 2500K Overclocked to 4.2GHz
Gelid Tranquillo Ultra Low Noise CPU Cooler (12dBA)
Asus P8P67 Motherboard with Crossfire, Bluetooth, USB 3.0 and Firewire (passively cooled)
Gainward GeForce GTX 570 "Phantom" 1.3GB Ultra Low Noise edition video card (6 heatpipes, 44 fins)
8GB Corsair Memory (2 x 4GB)
Corsair Force 120GB Solid State Drive (silent)
1TB Samsung F3 (the quietest 7200rpm 1TB drive on the market)
Scythe Quiet Drive 3.5 Internal HDD Silencer (silences HDD access noise without increasing temps)
Samsung Blu ray (the quietest blu ray player on the market)
680W BeQuiet Straight power Cable Managed PSU (semi active, 12dBa)
Windows 7 Home Premium 64bit OEM
