New PC build (£1300 plus current hardware)
29 Dec 2014
The "North"
Okay, it's that time again where I choose to upgrade my system and watercooling loop so I hope I'm posting in the right section.
Anyway I'm looking to upgrade my (Not old) system under the premise of redesigning the watercooling loop and shrinking the system down to a smaller form factor :D
Ideally I'm looking to decrease the size of the system to MATX/MITX but I haven't decided which is best whilst still maintaining a custom watercooling loop using hard tubing. The budget above is also allocated to buying a monitor and sound system but the rest can be used to upgrade the system.
Currently I have these components to transplant if necessary:
Intel Core i7 5820K
EVGA Micro 2 X99
4X 4GB DDR4 Dominator Platinums
D5 Pump (Needs a top change)
360mm radiator & 240mm radiator
5X SP120 fans
1X AF140 fan
EVGA 1000W PSU
So any ideas on what cases are the best and what other components will be good for the system will be greatly appreciated as SFF watercooled systems are not my specialty :)
Intel Core i7 5820K
EVGA Micro 2 X99
5X SP120 fans
1X AF140 fan
EVGA 1000W PSU
In all honestly I have exactly this setup, except I'm using a 280mm rad instead of 240mm, and I'm planning to do it in a CL S5 case :D
