- 27 Mar 2014
- Newcastle Upon Tyne
Hi folks,
Ive had my current rig around 2 years now and im looking to build a new machine as my GF will be taking my old i5 model. Ive lost touch with some of the new stuff thats hit the scene and was after a bit of advice on the build as I now stream and do some minor video editing on the system.
I was looking down the i7 skylake processors and a Radeon RX 480 for the GPU. Form factor isnt an issue anymore but think anything bigger than a midi tower would be overkill. Ive a few odd rigs up but then scrapped them and went back to re doing it. Just wondering if you guys can point me in the right direction for a good base.
Looking to spend about 1200 possibly 1000 if possible as i do want 2 new monitors as the one i have is almost 10yrs old.
Thanks as always.
EDIT: Will need SSD HD and windows too with my other half taking the old rig. Not sure how possible this is with the newer tech
Thanks as always.
