hi folks, a long time ago....I built via buying from OcUK around 2012 and not followed much on PC parts since then, using laptops for work and random bits of gaming since. So excuse my ignorance and becoming out of touch.
Now that I have bought a superb LG G4 TV, I was hoping to build a PC (or otherwise could be convinced to get a pre built one here) that can do the below two things, as my current older laptops struggle a bit.
My surface pro 6 is struggling to stream 60GB+ movies via plex to the TV for 4k HDR playback, and my 2021 macbook for gaming (I know..) is a bit poo especially over the last 12 months.
So ideally the build could do the following:
1. playback 4k HDR content / running plex server / high seas content, I'd presume having a 2TB disk drive [or more] would work here. I've a mikrotik home access point I need to confirm but pretty sure it can handle the wifi streams for plex HDR 4k streaming bit rates which I think are about 20-80 mbps (not sure how to debug my current plex setup that uses a surface pro 6, to see if why its breaking is it from: a) wifi limits, b) processor limits, c) i/o storage limits etc).
Note: as the home cinema aspects are here - it would be nice to have a quieter PSU and case fans setup plus an ability to turn off any case lighting would be appreciated to allow for the dark and quiet cinema environment for movies! Similarly I'd occasionally do some small LAN parties so having the case be not ultra heavy or huge would be nice too. Medium size is fine.
2. gaming at 4k HDR - I don't need to run AAA titles at ultra high settings with all the bells and whistles, probably that would be less than 5% of the time as usually I play indie games or play online messing around games with mates dota/counterstrike/party games. I would be happy if it could play something like last of us ii remastered / FF7 remakes / baldurs gate / cyberpunk / witcher 4 whenever it drops - at a decent frame rate with 4k resolution / hdr and medium-high graphics though.
I don't have a strict budget but nothing too silly as I don't need cutting edge tech here, ideally 2k pound or less, but if there's a good reason to increase it then I could be convinced.
No preference for amd/intel/nvidia etc, and I don't need a monitor nor keyboard/mouse/speakers.
Any advice is appreciated, and thank you for your time
