Hello all,
Hope this is the right place to ask - I built myself my first ever PC at the weekend after my trusty one of 5 years died, which was equal parts nervewracking and wonderful. It feels great to have learnt a bit how to put something together, and to have a PC that I better understand how it all works.
The specs are:
CPU: Ryzen 3600x
Motherboard: MSI Tomahawk x570
RAM: 32GB G. Skill Trident Z 3600mhz
GPU: GTX 980 (hanging onto the old card until the 3000 series is readily available and tested)
Storage: Samsung 970 EVO Plus
AIO Cooler: NZXT Kraken x63
PSU: Corsair TX650M 650w
Case: Lian Li O11 DYNAMIC
Case fans: 6 x ARCTIC BioniX F120 (powered by a Deepcool FH-10 fan hub)
I have a few questions about what I've built. I've been using it for a couple of days now and the great thing is it all appears stable, but there are a couple of cooling related questions I have:
1) The x63 pump is plugged into the CPU_FAN header as per NZXT instructions. I've set the pump up to be always 100% active. All the fans (six case & the two NZXT fans for the AIO) come off a single SYS_FAN header (via the SATA powered HUB). This means all the fans respond in the same way. Should the AIO fans be on their own seperate header? Would that be better practice?
2) I'm seeing the following CPU temps:
I'm also noticing a 'whine' which sounds a bit like there is a fly in the room. It's either going to be the NZXT fans or the Arctics but I haven't narrowed it down yet.
4) I have MSI Dragon Center installed which provides fan curve control, however the BIOS also provides fan control. Which one takes precedence? Is Dragon Center useful at all or would I just be better setting up fan stuff in the BIOS?
I appreciate your thoughts! Thank you very much.
The specs are:
CPU: Ryzen 3600x
30°C-45°C - Idle / minimal load in Windows such as typing this. Occasionally when opening windows and dragging things around it'll suddenly jump up to 50°C and then back down. It does seem quite jumpy! Is that normal?
60°C - 80°C Full load with Prime95. The fans are speeding up inline with CPU temp increase however is 80°C an ok top end?
3) I used 6 x ARCTIC BioniX F120 in the case because they were just easily availble to me at the time however would you recommend any particular others? I'm trying to find the sweetspot between quiet yet providing good airflow for the case.60°C - 80°C Full load with Prime95. The fans are speeding up inline with CPU temp increase however is 80°C an ok top end?
