New PC build but stuck with RGB fans
12 May 2020
Hi there, so I have my build here which has 6 Jonsbo RGB fans. I have and know how to setup everything else un apart from these fans. I have never used RGB fans, and the one's I have aren't ARGB don't get them mixed up.
I have a TUF B450M - PLUS GAMING motherboard with aura sync. This build is not fully finished and has no power supply plus HDD's so it's an ongoing build atm.
I need to know to to daisychain all thesee 6 fans together. I have one RGB header on my motherboard which I have no idea what goes where. Here are some picture's and I'll try my best to give a good diagram so you can point out what the connector's are and where they go.
In one of the pictures below I have outlined the connectors. So the green one's are for the RGB I believe which is a female and a male connector on each fan, the red one is a 3 pin one which I can't see anywhere where this one would go, do I need some sort of controller hub for all these to plug into? And lastly the yellow one which I think I know is a power connector.
I really need help trying to figure this out, I am lost when it comes to RBG fans rather than the simple ones. Any help guy's would appreciate it a lot! Cheers
https://1drv.ms/u/s!AlYrPtyqoagpgdUjzKJM9kUZ14yBVQ?e=SP3b4K
