I will be building my First build from scratch soon and have compiled the following spec:
Potential Spec: (prices not necessarily on this website)
Case & PSU
- NOW GONNA GET THE LANCOOL (3 x Intake Fans, 2 x Exhaust Fans) (want clear side panel, like the front ports & led fan switch on/off)
- OCZ ModXStream Pro 700w Silent SLI Certified Modular Power Supply
- Total - £140
Processor
- AMD Phenom II X4 Quad Core 965 Black Edition 3.40GHz - £140
Graphics
- ATI Radeon HD 5770 1024MB GDDR5 PCI-Express Graphics Card - £120
MOBO
- CHANGED - £85
RAM/Memory - CHANGED - £85
TOTAL - £640
Monitor & CD/DVD Drive – 22” Dell (already have)
HDD – 320gb + 60gb (already have)
WIFI Card – (already have)
Sound Card – (included on MOBO above!?)
Will be running Vista first, then Windows 7 home premium 64bit
I wanted the coolermaster scout because of the amount of fans it can take, the red led fans, and because i want a side panel to view the insides of the pc (why spend all that money not to see the amazing equipment
). I also liked the front ports and option to switch on/off the led fans. I dont want to spend more than 80quid on a case, and want the above on it.
Is this case good enough for the spec above, how overclockable would it be with the 3 intake, 2 exhaust fans, would it need water cooling? How overclockable are the parts above in general (motherboard, cpu, graphics etc)??
Any help/advice would be much appreciated!
Case & PSU
- Total - £140
Processor
Graphics
MOBO
- CHANGED - £85
TOTAL - £640
). I also liked the front ports and option to switch on/off the led fans. I dont want to spend more than 80quid on a case, and want the above on it. Is this case good enough for the spec above, how overclockable would it be with the 3 intake, 2 exhaust fans, would it need water cooling? How overclockable are the parts above in general (motherboard, cpu, graphics etc)??
