- 30 Sep 2020
Hi All
First time posting here so Hello
to everyone.
So yesterday I received the last two components for my budget home PC build, the CPU and GPU. Popped them onto the motherboard following all the instructions and all wired correctly.
However, when I went to boot up for the first time, the PC just powers on for about a second then goes off and repeats this cycle of ON and OFF until I hold in the power button on the case to switch off completely.
I spent most of last night disassembling the PC and starting from scratch, re-seating the CPU, checking for any bent pins, but the same issue occurred. There is a red led that flashes at the bottom right corner of the MB indicating that the issue seems to be with the CPU. I do have a video of the issue but as I am at work at the moment I can't upload it, will try later at home.
Specs are as follows:-
As I haven't built a PC in about ten years I'm at a loss at what the issue could be.
to everyone.So yesterday I received the last two components for my budget home PC build, the CPU and GPU. Popped them onto the motherboard following all the instructions and all wired correctly.
- Gigabyte Z390D Motherboard
- Intel i3 9100f CPU - stock cooling fan.
- Asus TUF GeForce GTX1650 Super GPU
- Corsair Vengence RGB Black Pro 16GB DDR4 3000MHz Ram (2x 8GB)
- Corsair Semi-Modular CX650M ATX PSU
. Will have to look that up unless there's a guide here.
