After following advice on this forum, I ordered the following specification:
Corsair HX 620W ATX2.2 Modular SLI Compliant PSU (CMPSU-620HXUK)
Gigabyte GA-P35C-DS3R (Socket 775) PCI-Express DDR2 & DDR3 Motherboard
Arctic Cooling Freezer 7 Pro CPU Cooler (Socket LGA775)
Coolermaster CM-690 Dominator - Black (No PSU)
Intel Core 2 Quad Pro Q6600 "Energy Efficient SLACR 95W Edition" 2.40GHz
OCZ 2GB (2x1GB) PC2-6400C4 Dual Channel Platinum Revision 2 XTC Series DDR2 (OCZ2P800R22GK)
PNY GeForce 8800 GT 512MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail
Samsung SH-S203D 20x DVD±RW SATA Dual Layer ReWriter (Black) - OEM
Seagate Barracuda 7200.11 500GB SATA-II 32MB Cache - OEM (ST3500320AS)
Microsoft Windows Vista Home Premium 64-Bit Edition DVD - OEM - 1Pk (66I-00788)
Today I put it all together, but I have not yet even been able to install the OS. After setting the dvd drive to boot priority I tried to install Vista. After it got to the end of the loading bar, I got a BSOD saying "irql_not_less_or_equal". I looked around the BIOS settings and found something that was set to 32-bit, and so I changed that to 64-bit and tried again. This time I managed to get as far as entering the product key, then start it installing. With relief, I went downstairs to have some food.
I came up a few minutes later though to find another BSOD, this time saying "PAGE_FAULT_IN_NONPAGED_AREA". I reset the BIOS, and tried to install again which resulted in the pervious error, except this time it occured while trying to choose regional settings.
Browsing the net I thought that the problem is most likely the memory, so I changed the voltage settings very slightly, but with no effect. Then i changed to the clock memory clock settings (or at which I think they were clock settings) from 5-5-5-15 (IIRC) to 4-4-4-12. As soon I had saved the settings, the computer switched off. Now any time I try to restart it I can no longer get any POST screen. The PC turns on and fans whirr, but there is no monitor output. Also, the fans spin quite fast, which happened before but only for a few seconds before the POST screen. Obviously it didn't like these settings, so I am considering resetting the BIOS by shorting the CMOS jumper pins on the mobo, but as you can imagine I don't feel very confident doing so right now.
I guess shorting the CMOs pins to reset the BIOS (as instructed by the mobo manual) is the next logical step, but is there anything I need to be wary of in doing so? Also, if I can get back to where I was before, what could the problem be? Does it sound like my memory and/or mobo is fried?
Any help would be very appreciated.
