Hi guys
Been asked to help a friend with a new PC build as his 8 year old Medion is dying. Ive suggested a custom build with good parts instead of going down that route again.
He has been using CS2 for years with 12mp files from a D700 so doesnt need massively fancy stuff - in fact what Ive quoted below is actually quite advanced.
So just looking to see if the spec below is recommended, all the bits work in tandem with each other and if any suggestions can be made to lower the price at all.
Also will the OCUK guys build this for me/him and how much extra would they put on top for this?
Many thanks folks!
Rikki
PS: Sorry about formatting, looked fine in notepad :S
Many thanks folks!
Rikki
Code:
PSU CX650 650W 80 Plus Bronze Power Supply (CP-9020122-UK) 70
CPU I5 7500 3.4GHZ 200
CPU FAN INC?
MOBO GA-Z270P-D3 Intel Z270 (Socket 1151) DDR4 ATX Motherboard 115
RAM Vulcan T-Force 16GB (2x8GB) DDR4 PC4-19200C14 2400MHz Dual Channel Kit - Grey (TLGD416G24 110
SSD 250GB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive (MZ-75E250B/EU) 120
CASE Carbide 200R Compact ATX Case - Black (CC-9011023-WW) 60
MONITORS sorted
HDDS sorted
GPU Radeon RX 550 Pulse 2048MB GDDR5 PCI-Express Graphics Card 80
SOFTWARE Windows 10 32/64-Bit - USB Pen Drive - Retail (KW9-00017) 90
HDDS P300 1TB 7200RPM 64MB Cache High Performance Hard Drive (HDWD110UZSVA) 45
