- 3 Apr 2010
- London
Hey folks!
I'm new to the forums, but not to OC's, I have bought from here before & been massively happy with the service & customer support.
Ok, so let me sort of cut to the chase. My neighbourhood had a dodgy power failure. First it fried the surge protector, then within a couple of seconds killed my beloved PC, (every component fried beyond repair). So, with the insurance money and some extra I'm about to order the list below, IF there's no problems with my selections any of you can see. There's several key things though that I'm PASSIONATE about and want to incorporate into the build, as follows, in no particular order,...
- Reliability
- Longevity
- Noise, (hopefully lack thereof)
- Driver support
- Cable management
- Cooling, (I won't be overclocking anything except the CPU to hopefully appx 4GHz)
- Price
- Gaming capability (BF2, BFBC, UT3, CoD4, CoDWM2, NFS:Shift & maybe Crysis),
- Ability to cope well with 3D rendering like 'Vue 8' (hi poly-count, textures etc), & HD video recording/editing etc
- Inter-compatability (Each part working together in harmony, connectability etc)
- Ability to control ALL the fans, (from outside the case with PC in situ), independently & safely to control noise & temperature levels. I MIGHT modify the case if it doesn't require a Dremel to allow the controllers to be accessed easily from the outside rather than having them internally.
I'd like to ask you all who've chosen to read this to be extra lovely n kind by going over the products in your own time and telling me if you spot any issues or problems I'm likely to encounter that I may have over-looked with the main features as listed above, in mind. Please leave your comments, views & opinions/criticisms below, thank you!
Asus ATI Radeon HD 5850 1024MB GDDR5 PCI-Express Graphics Card £224.99
Intel Core i7 920 D0 Stepping (SLBEJ) 2.66GHz (Nehalem) (Socket LGA1366) - Retail £199.99
Asus P6T Intel X58 (Socket 1366) DDR3 Motherboard £159.99
Patriot Viper 6GB (3x2GB) DDR3 PC3-12800C9 (1600MHz) Tri-Channel (PVT36G1600ELK) £129.98 x2 = £259.96
Microsoft Windows 7 Professional 64-Bit - OEM (FQC-00765) £116.99
Antec TruePower New Blue Modular 750W Power Supply £99.99
Fractal Design Define R2 Midi Tower Case - Black Pearl £79.99
Corsair H50-1 High-Performance CPU Watercooler (Socket LGA775/1156/1366/AM2/AM3) £66.99
Asus Xonar D1 7.1 PCI Sound Card (90-YAA0B0-0UAN00Z) £54.99
LG GH22NS50 22x DVD±RW SATA ReWriter (Black) - OEM £16.99
Belkin 6-Socket SurgeMaster with Network Protection - 2 Metre (F9S623UK2M) £16.44
Fractal Design 140mm Silent Cooling Fan £12.26 x2 = £24.52
Fractal Design 120mm Silent Cooling Fan £9.99 x2 = £19.98
Corsair Flash Voyager Mini 4GB USB2.0 Flash Drive (CMFUSBMINI-4GB) £9.99
Arctic Cooling MX-3 Thermal Compound £6.99
NZXT 8-Pin (EPS12V) Black Sleeved 25cm Extension Cable (CB-8P)£6.99
Akasa SATA-2 60cm Blue UV Data Cable x3 = £14.07
NZXT 3 Pin Fan Black Sleeved 30cm Extension Cable (CB-3F) £4.00
Akasa HD Audio 40cm Internal Extension Cable £3.98
Zalman Fan Mate 2 Fan Controller x2 = £7.02
Akasa AK-TK-02 Cable Tidy Kit x2 = £6.12
Akasa AK-FY320 3 Pin Fan cable splitter £2.34
Total : £1,417.97
I could be buying this as soon as 6th of April, but if you think I should wait, then of course I'll be eager to know your thoughts before making the decision to buy.
At some stage I want to get a good TV Tuner card, (maybe a BlackGold device), but the budget will have to wait for that for now, I have a TV as it is and only really want to watch F1.Oh, and yes, I know currently, (06:05hrs, 5th April), that the Asus Graphics Card isn't in stock and OC's are awaiting delivery. I have no idea how long it'll be before they're available, I did ask but they can't give me a definitive answer, but hopefully not too long!
Lastly, there's no HDD listed because I have a replacement Samsung F3 1Tb on its way to me as I type this, and a hopefully my Hitachi 500Gb sitting on my desk to be tested again; I hope it's ok!
So, yeah,.. there ya go.
Thanks again for your input folks, much appreciated.
Peace out!
Oh well. Will just have to hope for the best maybe.
Insurance firms!
(male, female, 3-pin, 4-pin, male 4-pin molex, female 4-pin molex etc, what can do what etc etc)
