I'm running games at 1920x1080 and Im looking at running games smoothly at high settings for as little as possible basically. with a budget going no higher than £800. Am i missing anything? I did benchmarks on the graphics cards and it seems this is a decent card for playing on high specs no? compared to others around the same price.
Must haves:
i5 2500k
Case below (unless someone has a reason against it)
Do not need:
Keyboard mouse monitor etc.
OS
DVD/BLU ray drive
NB: I used Anandtech for benchmarks
Krypton Z68 590i Intel Core i5 2500K 3.30GHz @ 4.40GHz Overclocked Bundle£245.99
Options applied to the above product:
Corsair Vengeance Blue Low Profile 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CML8GX3M2A1600C9B)£43.99
Gigabyte Z68AP-D3 Intel Z68 (Socket 1155) DDR3 Motherboard REV 1£81.59
Club3D HD 6950 2048MB GDDR5 PCI-Express Graphics Card (CGAX-69548A)£167.99
Seagate Barracuda Green 2TB SATA 6Gb/s Hard Drive - OEM (ST2000DL003)£89.99
Sharkoon T28 Midi Tower Case - Black/Red£59.99
OCZ ZS Series 650W '80 Plus Bronze' Power Supply£59.99
Sub Total :
£624.60
PS. how do you do that basket linkage with the pics and everything? or are people doing it the old fashioned way?
Update:
I have now built the machine, one problem! =(
I need a writer that doesn't have a sicking out bezel if possible. (Using Fractal Design R3 case)
Must haves:
i5 2500k
Do not need:
OS
DVD/BLU ray drive
Sub Total :
£624.60
Update:
