Hi all!
I bought a new set of components for upgrading my computer in November 2019 from OCUK.
It is an AMD Ryzen 7 3700X with an Asus TUF-X570 Wifi mobo and the Team Group Xtreem "8Pack Edition" 32GB (4x8GB) DDR4 PC4-28800C16 3600MHz Quad Channel Kit.
I cannot remember what settings i had when i set it up first time but it worked great for some time. One of the dimms became bad and i started having memory issues that memory test utilities would find. I sent them back and got a replacement. Memory tests now are fine, but i am getting radom BSOD screens on windows 10 and random window repaints all the time as well as chrome 'aw snap' while doing things any computer could handle (like typing this out).
Now, i have used settings a mate of mine that is a lot into these things gave me but also ones that a utility suggested (Zentimings) but i still got issues so i made the simplest of settings in the motherboard setup, so the memory is at the right frequency and just that.
Can anyone suggest what the 'right' settings would be or what i can do to make this memory work without issues? Mobo is on the latest FW and previous settings up until now were exactly the same, but FCLK was set to 'auto'. I just changed it to 1800 few minutes ago to see if this is going to fix the issue...
