Hi guys, i killed my dads mobo and i am having no luck finding a decent priced X58 Motherboard. So we have decided to buy a whole new computer
Here's the Specs:- CPU - i7 2700K <-- Overclocks better than 3770K
Motherboard - Gigabyte Z77X-D3H <--- Will i have any issues with using this board with the above CPU? Or can someone suggest a good Motherboard that i can use with the i7 2700K at a similar price point, and same features..
Ram - Corsair XMS 2x8GB 1600Mhz
Graphics - x2 GTX 680 <--- Already have these
Storage - 1Tb Samsung HDD, and OCZ Vertex 3 60GB
Sound - Asus Xonar DX/XD
PSU - Seasonic Platinum Series 860w <--- Will this be powerful enough to run the Rig and also the water cooling stuff??
Optical - 2 BlueRay Player things LOL and a all in one card reader <--- Already have these
And for cooling the system we will be water cooling the system
Here's the cooling specs: - CPU Block - XSPC RayStorm
GPU Block - XSPC Razor GTX 680
Rad - XSPC RX 360
Pump - Alphacool VPP655/ Laing D5
Res - Phobya Balancer 250 Black Nickel
Fans - Scythe Gentle Typhoons 1850RPM
Fan Controller - Lamptron 8 Fan Controller
Pump Anti Vibrator Pad - Aqua Computer - Anti vibration Shoggy Sandwich
Tubing - XSPC UV Blue
Compression Fittings - XSPC ones, same inner and outer diameter as the UV Tubing
That's everything unless i missed anything
Thanks in advance Harbz
Case - HAF 932, and i will most probs mod the case in order to place a 200MM Rad at the front of the case, so it will have enough cooling for all the parts
Rad - XSPC RX 360
