Hi,
Just found this forum yesterday, what a god send been looking for a popular forum to get decent advise for my new PC I'm hoping to build in the next couple of weeks.
I've got some idea's but would be greatful for opinions and some advice whats there please....
CPU: Intel Core 2 Duo E6600
CASE: Aplus Twin Engine Case
Mobo: Asus P5N-E SLi nForce 650
HDD: Hitachi Deskstar T7K500 NCQ 320GB SATA-II 16MB Cache
RAM: OCZ 2GB (2 x 1GB) PC2-6400 Dual Channel Platinum Revision 2 XTC Series DDR2
PSU: Enermax Noisetaker 370W EG375AX-VE
Graphics: BFG 3DFuzion GeForce 7300 LE Turbo Cache 256MB DDR TV-Out/DVI
Monitor: V7 L22WD 22" Widescreen LCD Monitor
I do not use my PC for gaming, its mainly used for video editing and encoding, work (excel, powerpoint, word etc) and internet. I'll be running XP Pro S2.
Regards
Regards
Not that you will use all that power mind, but it's always good to have a bit spare for future upgrades
Also, if you are going to stick with the 7300 card then get the Asus one as the BFG one uses Turbo Caching which uses your system RAM
