So iv ordered a upgrade bundle from OC its the defcon c1 using the rog maximus x hero now this is where im having my problem the bored has 2 rgb headers so i have ordered 2 1-3 rgb spliters so i can run 3 fans on 1 spliter and 2 fans and a led strip on the other. Will this overload the motherbored / rgb fan header
splitter 1
2 x https://www.overclockers.co.uk/cooler-master-masterfan-pro-140-ap-rgb-fan-fg-02d-cm.html
1 x https://www.overclockers.co.uk/cooler-master-masterfan-pro-140-af-rgb-fan-fg-02b-cm.html
splitter 2
1 x https://www.overclockers.co.uk/phanteks-multicolor-magnetic-rgb-led-strip-2-metres-ca-007-pt.html
Will this run fine or will it damage the headers or motherbored the splitter is a 1-3 trident cable by coolermaster also will it be fine if 2 of the fans are for the cpu rad cooler and there pluged in splitter and not the cpu fan header? help would be verry helpfull.
splitter 1
splitter 2
