I have finally gone ahead and purchased my new build shown below:
As you may notice, the two things I am missing is the Graphics Card and Monitor. I am still undecided on what to go for. The computer will be used for the occasional gaming (CS:GO, Battlefield..) and will be working more so with adobe software (Illustrator and Indesign).
If anyone has any recommendations or advice for me I would really appreciate your reply.
- Intel Quad-Core i7-4790K
- EVGA Super NOVA 850W PC Power Supply - Gold
- Gigabyte Z97X-Gaming 7 Intel LGA1150 Z97 ATX Motherboard (4x DDR3, 6x USB3.0, 6x USB2.0, HDMI, DVI-I, DSUB)
- Crucial BX100 250 GB 2.5-Inch SATA III Internal Solid State Drive
- WD 1TB 3.5 inch Internal Hard Drive - Caviar Blue
- Alpenfhn Matterhorn Pure Edition CPU Cooler 120 mm
- NZXT H440 Mid Tower Case with Side Window and 4 Quiet Fans for PC - White/Black
- Team Group TLRED316G2400HC11CDC01 - TeamGroup Vulcan RED 16GB (2x8GB) DDR3 PC3-19200C11 2400MHz Dual
- As for the graphics card, I have been looking at the MSI Radeon R9 390 GAMING AMD Graphics Card 8GB but wondering if I really need something as high spec as that. Are there any alternatives out there that will give great performance but not be so costly? The other concern I have is that my specification is of a fairly high standard so I do not want to dampen the overall performance by skimping out on a cheap g card.
- As for the monitor, I am looking for a 27" with either 2560 X 1440 or 1920 X 1080 ratio. Is there really any difference between the two? I have been recommended an IPS monitor as that will show the colours more vibrantly than others, (good for design software).
