New pc build, no signal to monitor :(
6 Oct 2020
Hey,
I was looking for a bit of advice before my next step, which is to visit a PC repair shop. Long story short, this is my third personal PC build. I have quite a clear knowledge on building them and my previous 2 builds worked straight away. With this current build, I have connected everything up, the PC powers on but there’s no signal to the monitor. I have spent a few hours testing different parts. First I thought it may of been the CPU, as I left it run for a few minutes, and then looked at the CPU, the thermal paste looked unheated. I then ordered another CPU online, same problem, so it’s the not the CPU. Iv tried different rams sticks, even no ram sticks, nothing. I’m totally stumped.
Please can I borrow someone’s wise mind, i just want to get my moneys worth now and actually have a working PC :).
There’s no bios, I can’t hear any clicks when I plug audio in. Tried the monitor with my PlayStation works fine, also different cables
My specs are
CPU - Intel i5 9600k
Mobo - msi b365m pro-vh ddr 4 matx
Ram - Corsair vengeance 16gb 2x8gb
Ssd 500gb
Hdd 2tb
Gpu - msi 1660 super venture Xs oc
Case - cas-520 xigmatek
CPU cooler - aerocool Cylon 4
Psu - EVGA 500w
Are all the fans spinning up? Any debug LEDs lit up?
My best guess, given you've tried 2 CPUs, is the mobo.
Does your CPU have integrated graphics? If so, hook your monitor up to that and remove your gpu.
Did you make sure to use the gold risers for the motherboard? Does anything get power when you turn it on? If not, try starting the PSU with a paperclip and see if it starts up ok.
