- 1 May 2004
Hi
Ive just finished building my new PC, well the mobo,cpu,ram and gfx are new, the HDD and DVD are from a previous pc.
it turns on fine and goes though to the bios screen where it says it needs a DVD to boot from. So i put one in, it restarts, goes through the verifying (i think?) loading bar screen and then goes to the "windows is starting" screen. however at the end of that screen it reboots.
the hard drives were in my previous PC and have not been formatted yet, I thought they would be able to be formatted as part of this procedure. Is that the problem or does this point to something else? Ive tried with both my existing windows vista disc, and with the latest windows 7 RC burned to a dvd.
This is my first pc build from scratch by the way, so go easy
happend to my mates would take ages to load windows then restart after the loading screen
however you could try you hard drives in another PC
