Hi guys, following a thread and Sycho's advice (member of these forums of course!) I've built a computer with the below specifications, or rather my brother built it as he's quite experienced at doing so.
Intel Core i5-4670K 3.40GHz (Haswell) Socket LGA1150 Processor
Gigabyte Z87-HD3 Intel Z87 (Socket 1150) DDR3 ATX Motherboard
Seasonic G series 550w '80 Plus Gold' Modular Power Supply
TeamGroup Elite Black 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TED38GM1600HC11DC01)
Corsair Carbide 200R Compact ATX Case - Black (CC-9011023-WW)
CoolerCooler Master Hyper 212 Evo CPU Cooler
MSI Radeon R9 280X Gaming Edition OC 3072MB GDDR5 PCI-Express Graphics Card
The issue is the computer boots up but doesn't even get to the stage of turning the monitor on and don't appear to have a speaker cable in the case to attach to the motherboard in order to hear bleeps.
The computer boots up for around 6 seconds and restarts it's self in a constant loop.
We have tried all of the following:
*re-seated CPU
*checked for shortage issues (motherboard standoffs etc)
*tried both ram sticks seperately in different slots in all possible combinations including no ram
*tried a replacement PSU that is definitely working as is currently supplying my brothers PC
*tried the above with and without a dedicated graphics card
*tried with only power button connected to motherboard
*using mx3 thermal paste not the paste it comes with
*tried absolutely bare minimum which consisted of motherboard, CPU, cooler, PSU, ram (and also without RAM)
Tried resetting CMOS, resetting battery, checked every wire/connection/whatnot multiple times to be sure, tried multiple power cables to no avail.
Perhaps worth noting that when fully built all the fans come on including case fans however they are extremely quiet and very slow, don't know if this is an indicator but it's almost as if they're not getting enough power hence trying a different same wattage PSU and having the same problem as described.
Any help would be greatly appreciated but at this point we've much boiled it down to either a faulty motherboard (again, no audio or lights to detect specifically) or the CPU due to the same problem happening whether or not the GPU is installed.
Thanks in advance
*re-seated CPU
Thanks in advance
