- 3 Jan 2008
My current PC has been having a few issues recently. The main one has been a failing PSU. This has made me think about building a new system as my current one is still reasonable but not as efficient as I would like.
My two main uses are Photographic Editting (which current maxes out my CPU suite quickly) and playing Flight Simulator X which works OK on low settings but even then can still struggle.
I'd like to try and do this for a little cost as possible, perhaps around £500-600 at most.
I have been checking out some components and wondered if you could give me advice on whether they offer best compatibilty and bang for buck?
1 x Intel Q6600 Core 2 Quad "Energy Efficient SLACR 95W Edition" 2.40GHz
1 x ASUS P5W DH Deluxe SKT 775 dual-core Core2Duo 8 Channel audio ATX
2 x GeIL 2GB (2x1GB) PC2-6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC) for a Total of 4GB
1 x OcUK GeForce 8800 GTX 768MB GDDR3 HDTV/Dual DVI (PCI-Express) - OEM
1 or 2 x Seagate Barracuda 7200.11 500GB SATA-II 32MB Cache - OEM (ST3500320AS)
1 x Antec Solo Quiet Mini Tower Case (Or something better but similary priced?)
I have just purchased a Antec TruePower Trio 650W PSU - With 3x 12v Rails and 120mm Fan to keep my current system alive while I plan for a new build. To save money I may use my old cheap-o case and 300GB SATA drive and leave purchasing those components until later. The Graphics Card may also have to wait until funds become available.
If anyone has suggestions for better / cheaper components then please let me know. Also if there are new products soon to be released that would be worth waiting for, please let me know. I've not previously done much overclocking and it's not a major priority. That said if the components support it I may try.
Finally I did see bundle deal BU-092-OK and wondered whether that would be worthwhile?
Cheers,
Steve
Cheers,
Steve
, then may I suggest buying an separate cooler since the Intel stock cooler won’t cut it if you are looking to overclock. The
