New PC Help
16 May 2009
Hi everyone,
I am finnishing my MSc at university next month, and I have saved some money up to buy a new gaming PC sort of my own present to myself for sticking out the MSc! (It got very very boring near the end) :o
Anyway... I was thinking about buying a complete system from OCUK, or maybe buying one of their customized systems (I dont really want to build one).
My budget is £1500 and I currently have a 24" ViewSonic monitor so I sort of need it to be able to play games at its native resolution. :confused:
I wanted it (if possible) to be as future proof as possible so I wouldnt need to upgrade for another 2 years or so.
The main games I wanted to play on it were the upcoming ArmA 2 / OPF 2 games - would be nice to play them with all the eye candy!
So yes, could anyone recommend a system? (Is OCUK the best place to buy complete systems from?) ;)
Cheers! ;)
K Dynamite
Hello and welcome to the forums, be sure to check the FAQ,
Does this look ok: Clicky or have a look here to see if any take your fancy.
There was a Overclockers buld thread around I will see if I can find it.
Hi - what about this one in comparison - better or worse than the one you posted?
my.php
Looks good, the one I linked to is pre-overclocked and a different gpu.
But the 2 gpu's in your one I think will be faster.
