Hi folks,
At the moment I'm playing an MMo called RIFT; my computer is about a year a little bit old and ive added a few things to it, but it really lags badly ingame with low fps and its terrible for my gaming experience. I have to make sure all my graphics are really low and even then when lots of things are going on and the loading its pretty bad.
The system I have at the moment is: (Specs)
AMD Anthlon 2 - 2.8Ghz x4 2MB Cache
6GB RAM
Standard HD
SSD Vertex 2 80GB
OCZ 600W Power supply
Radeon HD 6870 1GB DDR5 Ram
I've added RAM to it in the past year, and the GPU is pretty new - but after i bought it i was told by some friends that Nvidia is better and they woukd never buy a radeon. at this point i cursed a lot.
They also said that an Intel is a far better CPU to have and it would be better for the gaming experience as they sponsor the gaming companies to make it more compatible with their products and AMD are the cheap version(s). they reccommended the I5 as appose to the I7 because theres not much difference when it comes to value for money.
I've been looking around to see what I could find but to be fair my search isn't going very well - I was just wondering if you guys had any thoughts or reccommendations on possible systems? the computer is solely for gaming purposes, and if possible i would like to be able to play RIFT on high graphics with no problems at all. I was looking at Alienware but I imagen you could probably get just as good for cheaper or a similar price perhaps?
Price range is around £900 - £1000, just so you know - less is fine!! you dont have to spend that much!
I have my own 25 inch monitor so thats not necessary, just the pc alone would be great.
thanks guys hope to hear back soon,
James
6GB RAM
Standard HD
SSD Vertex 2 80GB
James
