- 25 Aug 2013
I am planning an upgrade after a long gap (6 years I think). I used to do it a lot but after such a gap I am a bit out of the loop on what is required these days.
I intend to give my current PC to the GF and start from scratch. I only want to keep the Graphics card which I upgraded recently. (AMD7850)
Currently I have a Core2 duo. 2.13Ghz with 6gb RAM. So this should feel like a massive upgrade I hope.
I don't need anything outside the box as far as i can think. I have all the software too.
I use my PC for gaming now and then but also for working from home and also for video/photo editing and my current PC is giving up with my new GOPRO.
My current plan is to get the spec below but I am unsure on a few things. Budget is flexible in both directions if things are either a waste of money (i7?) or something better is worth it.
The SSD is for a boot partition (dual boot windows and linux) and the Data disk is for larger installations like steam and videos/photos I am working on.
I have a server with much more storage as well so the sizes below should be fine.
Questions:
Thanks in advance for any advice!
YOUR BASKET
1 x Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - Retail £275.99
1 x Gigabyte Z87-D3HP Intel Z87 (Socket 1150) DDR3 ATX Motherboard £103.99
1 x Kingston HyperX Genesis Blue 16GB (2x8GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX16C9K2/16X) £99.95
1 x Samsung 120GB SSD 840 SATA 6Gb/s Basic - (MZ-7TD120BW) £79.99
1 x XFX Pro 650W Core Edition '80 Plus Bronze' Power Supply £64.99
1 x Western Digital Caviar Blue 1TB SATA 6Gb/s 64MB Cache WD10EZEX - OEM ** Single Platter ** HDD £51.95
1 x Samsung SH-224DB/BEBE 24x DVD±RW SATA ReWriter (Black) - OEM £17.99
Total : £706.85 (includes shipping : £10.00).
Questions:
- 1) Is there any reason to get i7 over i5. I see some posts about hyperthreading not being used much. I do play games but also want to use this for go pro video editting and photo editting. So if I can save money and get an i5 that would be good.
- 2) Is the PSU well specced for the the chosen components.
- 3) Is the motherboard any good? There is a massive amount of choice and to be honest even the cheapest one seems to cover all the requirements I have. I won't be doing any overclocking. It was a bit of a guess and I have had gigabyte before.
- 4) I specced haswell as this seemed future proof and has latest architecture etc. But is that even a good idea? This will likely be the backbone of my desktop for quite a while.
- 5) I havn't realy thought about case and cooling. What should I get. It would be nice if it was quiet!
- 6) What have I not thought of?
YOUR BASKET
