Hi,
Can you spec me a PC that will be powerful enough to run Autodesk Inventor/AutoCAD 2020 comfortably?
I will be using this in a network environment and will need to include Windows 10 Pro. Budget is ideally around £1000, however can go up to £1500.
Inventor recommended spec is:
CPU 3.0 GHz or greater, 4 or more cores
20 GB RAM or more
4 GB GPU with 106 GB/S Bandwidth and DirectX 11 compliant
https://knowledge.autodesk.com/supp...-requirements-for-Autodesk-Inventor-2020.html
Thanks in advance.
20 GB RAM or more
Thanks in advance.
