*** New Phanteks Enthoo Pro 2 Cases ***
3 Mar 2020
The Enthoo Pro 2 has been designed with extreme performance in mind, featuring Phanteks’ innovative ‘High-Performance Fabric’ that brings ultimate airflow performance with much lower flow restriction compared to any metal mesh.
In stock Now
Phanteks Enthoo Pro 2 Full Tower Case Tempered Glass Window DRGB Satin Black @ £124.99 inc VAT
Full-Tower PC case, High-Performance Mesh fabric front panel, D-RGB controller buttons, large internal capacity for multiple components
Only £124.99 inc VAT.
Phanteks Enthoo Pro 2 Full Tower Case Closed Window Satin Black @ £115.99 inc VAT
Full-Tower PC case, High-Performance Mesh fabric front panel, durable construction, large internal capacity for multiple components
Only £115.99 inc VAT.
ORDER NOW[/URL]
im loving this case. its a shame my ITX is the main system and MATX is secondary. so i dont think this would work for my current dual system setup
that satin version looks lush. i have a fractal define r2XL at the moment, said i wasn't going to change it!
I fail to see the point of buying 14 RGB halos for £300 to then slap £5.99 fans on there. You know you can just get BETTER fans with RGB for less :D. I think the case comes in with PCIE adapter as well and supports vertical cards (my p600s comes with them) so might not need one?
Great case though, wish I had seen it earlier I'd have probably gone for it over the p600s at that price.
yeah i was just making a point that phanteks want to get more out of you for the accessories. those 5.99 fans come up top for airflow against a major brands, as someone linked me a test in another thread. Im not going to upgrade to this anyway as my main system is ITX and secondary is MATX. my setup is a bit back to front to get this case
In the same boat with a new build. Wish Phanteks would realise some people would prefer the top secondary build to be matx. They need more of a cube, dual chamber midi case.
@petedool72 is this case due back in stock and do you know if phanteks have any other dual system cases up their sleeves between now and xmas
Good morning sorry for the delay, i had a long weekend.. the following we should have some due mid November and larger delivery due in dec..
dual system cases up their sleeves between now and xmas- not to my knowledge
