new pots and pans for £100
I'm always a little unsure about pans. That Raymond Blanc set looks decent, but I think I would rarely use anything other than the skillet. The saucepans don't look big enough for most things.
I enjoy using my cast iron skillet, but worry about using it to sear meat if I think I might want to deglaze the pan. For some reason I think that if I deglaze I'm going to take some of the non-stick seasoning away. Am I wrong?
I would not deglaze a cast iron skillet, and since you already have one I would just get a few stainless pans and a stainless skillet if needed.
I changed all my cookware to stainless, cast iron and some stone oven ware years ago.
I bought my stainless pans when I moved house about 14 years ago and they are still good. Previous to then I went trough a few Aluminium and non-stick ones every few years, not no mention that Aluminium 'may' cause toxins.
Meyer Anolon Professional (the Raymond Blanc ones). Just do a search on this forum for them, you can't get anything better for the money.
I have one stainless pan with doubles as a steam for mashing potato's. Other than that they are for looking good without anything like the even heat distribution of an analon.
Just watching the even heating just boiling water or heating milk in an analon gets me moist ;)
they will last a lifetime if you take care of them
I wouldn't be without a non stick pan for some things but they're a disposable item. A decent stainless steel pan will last a lifetime while also standing up to a lot of abuse.
I've no problem with the heat distribution on a well constructed stainless steel pan.
Le cruseat....I miss cooking with those. Sadly a kitchen fire wiped out a few...not the fire itself, the water/foam putting out the fire. And my mum and I can't lift the weight of a full pan due to bad wrists.
How many people are you cooking for?!
That RB set of pans ought to see any home-cook through thick and thin unless they are cooking for a large family or regularly braise entire joints of meat.
And even if they do, there's a very decent 24cm stockpot in the same range which is probably too large for home use, if anything.
Circulon pans are fantastic.
That they are.
After years of cooking with 'regular' Anolon pans I've recently swapped everything out for its Circulon equivalent and I'd never go back. Now that they've narrowed down the non-stick circles and toughened up the pans they ought to last a lifetime, given the appropriate care and attention.
Meyer Commercialware is still the best when it comes to sheer longevity, but it's got no real place in a domestic kitchen. Shame, as that 22cm Flared Sauté pan is a thing of beauty...
