New power supply needed (maybe?)
4 Jan 2012
Good Afternoon,
Switched my PC on yesterday and without my knowledge the power cable was half hanging out. There were a lot of sparks and now the computer does not boot. I'm guessing its the power supply that has gone.
Can someone please spec me a new power supply, as cheap as possible please.
Hardware is currently:
Radeon R9 Nitro 390 8192MB GDDR5 PCI-Express Graphics Card with Backplate
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor
Gigabyte Z68XP-UD3 Intel Z68 (Socket 1155) DDR3 Motherboard
XFX 650W XXX Edition Modular '80 Plus Bronze' Power Supply (DEAD?)
Kingston HyperX Genesis Grey 16GB (4x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX) [KHX1600C9D3X2K2/8GX]
250GB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive
Thanks all!
You only need a quality 550W PSU for that build. For non-modular, I'd suggest this:
https://www.overclockers.co.uk/antec-truepower-classic-550w-80-plus-gold-power-supply-ca-202-an.html
Or for fully modular, this:
https://www.overclockers.co.uk/evga...plus-gold-modular-power-supply-ca-023-ea.html
Both are decent units that are more than capable of powering this system. Not really cheap, but should last you a long time Hopefully it's just the PSU that's blown.
PS. What is your budget for a new PSU?
No real budget but would like to keep it as low as possible, fingers crossed it's only the power supply. Sparks lit up the entire room though :(
Here's hoping the protection circuits did their job then.
With a 390, you're going to need a 550W PSU. The Antec unit I suggested will do the job and is probably one of the cheapest good quality PSUs around.
Non-modular means that all of the PSU cables are hard-wired into the unit. Fully modular means that the cables plug into the PSU and into the device. This means you can use as many/as few cables as you need.
If you want a cheap PSU for testing, then something like this should be good enough to power a 390:
https://www.overclockers.co.uk/xfx-xt-series-500w-80-plus-bronze-power-supply-ca-022-xf.html
At the very least, you can then boot into windows using the onboard graphics - take the 390 Nitro out. Then if everything seems OK, put the 390 back in and try booting with the GPU in the system. I wouldn't try anything too demanding as it is a cheap PSU.
