new power supply
15 Feb 2007
not sure if this should be here or in oc/cooling.
adding a tec or maybe 2 to my system, initially a 227 pelt, 25A, 12v
don't see the point on spending 100squid on a meanwell so was concidering a Silverstone SST-OP750, 12v output of 60amps on a single rail.
everyone seems to be raging about dual or quad rail psus but that obviously wouldn't work (unless you can wire the pelt to run from 2 rails?)
so would this be at all decent?
I'd go for the Etasis ET850. I was looking for a high output PSU a while ago and settled on this from reading many reviews.
I'd have to check the manual, but I have four PCI connecters and I'm sure they all run off different rails, all shared with mobo/cpu/drives etc.
