The vastly successful Asgard chassis from Xigmatek shaped the industry when it was first released, offering an excellent price/performance ratio. The new Asgard Pro aims to follow in these footsteps while offering all the modern features needed to build a potent system, including a more flexible interior, upgraded air flow and proper inclusion of USB 3.0. Take a look below to find out more
Xigmatek Asgard Pro Gaming Case - Black @ £34.99 inc VAT
"Asgard"-The Property of Æsir and castle of Odin. As the country of Gods, the inviolable Asgard is the world's first black coating entry-level chassis - what a milestone. Furthermore this chassis is supplied with 2 x 120mm preinstalled black fans, and 5 more fans can be mounted in different areas for best possible airflow. The 3 x 5.25" bays will be able to house all your optical drives, there are also 7 trays for your 3.5" HDDs so you can feel free to "DIY". With a great tool free design and a "gorgeous" look are just two of the many points why this chassis is a "must have chassis" not only for enthusiast but also for pc beginners.
- Dimensions: (W) 200 x (H) 445 x (D)470 mm
- Drive Bay: 5.25" External x 3 (single side tool-free holders)
- 3.5" Internal HDD x 7 (single side tool-free holders)
- 3.5" External FDD x 1 (single side tool-free holders)
- 2.5" Internal HDD x 1 (by screw, downside of ODD cage)
- Expansion Slots: 7 slots
- Motherboard Support: ATX, Micro ATX, ITX (with backside hole for CPU cooler)
- Power Supply: Standard P/S2 ATX/EPS power supply units on downside space with anti-vibration rubber.
- Front Cooling: Pre-installed 120mm black fan x 1 (140mm available.)
- Rear Cooling: Pre-installed 120mm black fan x 1
- Left Side Cooling: Two 120/140mm fan available.
- Bottom Cooling: 120mm fan available.
- Top Fan: Two 120/140mm fan available.
- I/O Panel: Power button, Reset button, USB3.0 x 1, USB2.0 x 2, Audio in/out x 1 (HD Audio)
Only £34.99 inc VAT.
PRE-ORDER NOW
PRE-ORDER NOW
