***New price Antec Mobile Products - SP1 Portable Wireless Bluetooth Speaker & Speaker-phone ***
7 Feb 2011
Stoke on Toast
Another New Price which will not be going back up for you is this Antec Portable Wireless Speaker. It's in stock with free shipping available to eligible forum members.
Antec Mobile Products - SP1 Portable Wireless Bluetooth Speaker & Speaker-phone (Forest) @ £59.99 inc VAT
A.M.P by Antec - SP1 Portable Wireless Bluetooth Speaker & Speaker-phone
SP1 is a simple, small & outstanding sound performance wireless speaker & speakerphone. Tons of undistorted music power is delivered from this compact speaker box. Easy connection with Smartphone, Computers, Tablet & all other Bluetooth devices have made sharing music very much part of present life. Auto notification for all the incoming call is another value added feature of this product. Stereo input Aux jack has widened its field of applications.
Be Free Stream digital media wirelessly from Bluetooth enabled device.
Let’s Chat A built-in microphone lets you pick up and place calls.
Limitless Listen to your favorite song, watch a movie or play games with big sound.
Ready, Set, Go Up to 10hrs playback time; the SP1 is always ready when you are.
Product features:
• Wireless audio streaming thru Bluetooth
• Hand free capability with build in Mic & echo cancellation
• 3.5mm Aux input ready for any audio devices
• 3 buttons for simple operation
• Long lasting rechargeable battery
• White LED indicator for Bluetooth status
• Low battery indication by both Red LED display & tone sound
Bluetooth function:
• Bluetooth Ver. 2.1 + EDR
• Supported Codec – SBC
• Support CVC echo cancellation
• Simple Pair & Auto re-connect to paired devices upon power on
• Single button for answering & cancelling incoming call
Aux function:
• Stereo Input Source
• Auto change to Aux mode when Aux cable connected
• Auto switch back to BT mode when Aux cable removed
Power supply:
• Rechargeable Li-Ion battery 3.7V @ 1500mAh
• Micro USB ( for DC 5V in only)
Specifications:
• Range up to 10m
• Up to 10hrs* playback time
• Connect with Bluetooth or 3.5mm Stereo Cable *Varies by volume level and media content
Overview
Getting started:
•Charging the battery before use is recommended but not required. The SP1 ships pre-charged however initial charge will vary. Connect the included Micro-USB cable to your SP1 and a USB slot of any PC or Mac to charge. The LED will alternate between red and white while charging and will turn off when fully charged.
Pairing mode:
•Push and hold the center button for 6-8 seconds until the LED constantly flashes white. You are now in Pairing Mode.
Socializing:
The SP1 can be used as a wireless speaker-phone. The built-in microphone will only function under wireless connectivity via Bluetooth.
Answer/End Calls
•Press the center button to answer and end calls.
To Make a Call
•Use your phone to dial. Your SP1 will then function as a speaker-phone.
•Call Waiting
To answer another incoming call, just press the center button. The original call will then be placed on hold.
Was £74.99 Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
Antec Mobile Products - SP1 Portable Wireless Bluetooth Speaker & Speaker-phone (Magma) @ £59.99 inc VAT
Product features:
Bluetooth function:
Aux function:
Power supply:
Specifications:
• Range up to 10m
Overview
Getting started:
Pairing mode:
Socializing:
Answer/End Calls
To Make a Call
•Call Waiting
Was £74.99 Inc. VAT
ORDER NOW
Antec Mobile Products - SP1 Portable Wireless Bluetooth Speaker & Speaker-phone (Snow) @ £59.99 inc VAT
Product features:
Bluetooth function:
Aux function:
Power supply:
Specifications:
• Range up to 10m
Overview
Getting started:
Pairing mode:
Socializing:
Answer/End Calls
To Make a Call
•Call Waiting
Was £74.99 Inc. VAT
ORDER NOW
