New printer, too much shaking?
7 Jul 2003
oh I do like to be beside the seaside
Just setup my first ever printer (Elegoo Centuri Carbon)
I’m not sure if it’s shaking too much, or is it normal?
It’s sitting on a floor tile, on an anti-vibration pad and then the table.
This is the Benchy I printed.
Try on hard surface directly on floor or concrete slab then printer . You can put rubber between them but basically something like a cut up inner tube patch just to reduce noise. You don't want soft rubber pad that causes micro rocking. Similar principle to loudspeaker on speaker stand really.
Print looks fine though
