So I recently upgraded my old Phenom II to an FX8370 and have run into a very strange issue. Upon booting initially it worked fine and after the POST it continues to work perfectly. However every few restarts it will refuse to POST. I clear the CMOS, I put in the exact same identical saved settings and it will boot that time and the next few times before refusing to POST and repeating the cycle. The only changes to my system are the CPU and RAM frequency (plus I flashed the motherboard from its pre-bulldozer firmware).
Curiously I haven't seen this issue the times I have switched back to the Phenom II. The RAM does change and that potentially may be an issue I'm running it at factory settings and timings and have seen it play up at around 2000 instead of 2400MHz. Everything is set to factory recommended, Nothing currently installed has been pushed past factory settings (Phenom II had been toyed with but not left overclocked but it works fine). Most BIOS settings are at auto/default.
I am running an FX 8370, Asus M5A99X EVO mobo, 16GB Corsair Vengeance Pro, XFX Fury (incredible price here at overclockers). I've also got a full set of PCI-E cards, but those have been fine for years. TP Link wifi, Sound Blaster Recon3D (pre-Sound Blaster Z with the same processor), Sound Blaster X-Fi xtremeMusic PCI (very early 1st generation X-Fi, PCI non-extreme, my hardware baby), 850 Evo, 500GB only (lost a harddrive recently though after the issue started). XFX 550 watt PSU, can check the exact model in the morning if needed. Mobo PSU and PCI cards are all 2012 era, CPU, RAM, GPU and HDD are all under a month old.
If it manages to POST it will be perfectly fine for anything. Has done everything from running games and benchmarking to re-installing windows. Temperatures are still fine and will refuse to POST at CPU 40 degrees.
Feel free to ask anything else, hardware, tests, whatever really. It may be something incredibly simple as I've got no experience in errors like this so my apologies if it is. Thanks for taking the time to read.
