** New Product Aerocool Dead Silence DS200 **
7 Feb 2011
Stoke on Toast
Just a quick announcement that we will be stocking these shortly and they will be available for pre-order in a range of colours.
Aerocool DS200 Green Edition @ £75.95 inc VAT
After the successful launch of DS Cube in the last season of 2013, Aerocool is glad to introduce DS-200: a new model from the same DS(Dead Silence) series which is of a mid tower size with more advanced features such as built-in fan controller with LCD, noise insulator on side panels, support 240mm/280mm water cooling system on both front and top panels and an additional top cover included to make sure the "Dead Silence" is achieved. For those of you who likes DS Cube but did not prefer the small form factor, now it is you chance to own a DS case in mide tower chassis and with tons more features!
- Super-Silent mid tower gaming case solidly built with 0.8mm steel to block out most of the noise.
- High quality noise insulator on both side panels to further reduce noise.
- Leather coated front and top panels with smooth surface finishing (except standard model).
- Built-in fan controller on top panel:
* Controls a combined fan power of max. 25Watt with 4 speed settings (stop/low/mid/high).
* 7 backlight colors selection.
* Case temperature display (Celsius or Fahrenheit).
- Removable 3.5” HDD cage supports long graphic card up to 410mm.
- Supports either 240mm or 280mm water cooling system on both front and top panel.
- Supports max. CPU cooler height of 170mm.
- Supports max. PSU length of 220mm.
- Removable PSU dust filter for easy cleaning.
- Shock-proof rubber for 3.5” & 2.5” HDDs and PSU.
- Pre-drilled holes for cable management to reduce cable mess.
- Supports up to 5x3.5” HDD or 7x2.5” HDD/SSD installation.
- Install up to 2x12cm or 2x14cm or 1x20cm fans on top panel / 2x12cm or 2x14cm fans on front panel and 1x12cm fan at rear of case.
- Additional top cover (silence version) included for reducing noise.
- 2xUSB2.0 / 2xUSB3.0 / HD Audio+Mic
Specifications:-
- Case Type: Middle Tower
- Steel Thickness:0.8mm
- Motherboards: ATX/Micro ATX / Mini ITX
- Case Dimensions(W x H x D):210(W) x 527(H)x 485 (D) mm
- 5.25” Drive Bays: 2 (Exposed)
- 3.5”FDD Drive Bays: 1 (5.25” To 3.5”Adapter)
- 3.5” Drive Bays: 5 (Internal 3.5” HDD Tray, all compatible with 2.5”HDD/SSD)
- 2.5” Drive Bays: 2 (Internal 2.5” HDD Tray)
- Expansion Slots: 7
- Max length space available for PCI slots: 290mm (410mm – Without 3x3.5" HDD Tray)
- I/O Ports: 2 x USB3.0 / 2 x USB2.0 / HD Audio + Mic / 1 x Temperature LCD display and Fan Controller
- Height limit for CPU coolers: 170m
- Air Cooling System: Top :2 x 120mm fans or 2 x 140 mm fans or 1 x200mm fan (Optional)
- Front: 2 x 120mm fans or 2 x 140 mm fans ( Included 1 x 140mm Black fan)
- Rear: 1 x 120mm fan ( Included 1 x 120mm Black fan)
- Water Cooling System Top : 120 / 140 / 240 / 280mm Radiator Installation
- Rear: 120mm Radiator Installation
- Front: 120 / 140 / 240 / 280mm Radiator Installation ?Both front and top can support Radiator Installation - MAX. 45mm thickness(height)
- Net Weight: 9.9Kg
- Power Supply: Standard ATX PS2 (Optional)
Only £75.95 inc VAT.
ORDER NOW
Nice looking cases! As above, would be awesome if they had a window. Though presumably less silent then?
Not a Fan of Aerocool but their DS cases do look nice no doubt a window version is coming like their cube case.
Did see them while scouting for cases and glad it supports ATX. It looked a Mini or Micro when I first laid eyes upon. If these come with a window some time I will seriously consider one. Any rubber grommet holes on these?
Edit: Seen the insides of it, how is the room for the 4 pin power cable in the top corner? I have a braided extension already.
I have the dead silence m-atx case and it is beautiful. Only downside is the front doesn't have a mesh option, not being able to bring in cool air really hinders it. I sent an email to aerocool about ordering spares to mod it myself and got no response, so not very good customer service!
See if anyone in the ocuk buyers team have a contact at aerocool
£95!!!...who do they think they are..Phanteks or something.
Way too much money for the brand.
what an odd remark.
firstly, the case is £75. not £95. A windowed side panel isnt a default addition to this case as the whole point of the case is for quiet computing.
Why is it way too much money for the brand? A well built Mid Tower case with noise insulation, LCD Fan controllers and other premium features for £75 is about right. Regardless of the brand.
what an odd remark.
Having the fan controller and temp display makes it quite good value.
Good point. I tried emailing [email protected]
rjkoneill: Know someone directly worth contacting? Would love some spare front panels to mod!
I fear this design is going to have the same problem, those front 120mm/140mm are unable to draw in cool air. I agree this box is about quiet computing, but even so, I'd of thought they would people the option to purchase front panels to mod. Or at least reply to my original email :p
