** New Product Antec Wedge Bluetooth Speaker **
7 Feb 2011
Stoke on Toast
Antec Wedge Bluetooth Speaker - Blue & Black @ £14.99 inc VAT
Say hello to WEDGE, a triangular little Bluetooth® speaker that boasts three nifty functions. Built- in suction cups grip onto smartphones and tablets with up to 7.9” screens and angle your device comfortably for typing, browsing, watching movies, or reading. The 40 mm driver delivers clear, full sound, giving you a much better alternative to tinny-sounding and inadequate cell phone speakers. With its built-in microphone, WEDGE is also a speakerphone, so you can seamlessly handle phone calls in between songs on your playlist. The 33-ft. (10 m) Bluetooth® range enables wireless freedom, making WEDGE the perfect accessory for your mobile device.
Specifications:-
- Bluetooth version : Bluetooth 3.0
- Bluetooth Profiles : HFPV, A2DP, AVRCP
- Connection : Bluetooth or 3.5mm Stereo Cable
- Wireless Range : Approx. 10m (30 ft)
- Battery : 400 m Ah Rechargeable lithium-polymer battery
- Playback Time : Up to 4 hrs*
- Speaker : F 40mm
- Power : 4O 3W
- Frequency Response : 100Hz-18kHz
- Microphone : Built-in microphone
Only £14.99 inc VAT.
ORDER NOW
Antec Wedge Bluetooth Speakers - White @ £14.99 inc VAT
Specifications:-
- Speaker : F 40mm
- Power : 4O 3W
ORDER NOW
Antec Wedge Bluetooth Speakers - Black @ £14.99 inc VAT
Specifications:-
- Speaker : F 40mm
- Power : 4O 3W
ORDER NOW
Any reviews for these? Been looking at cheapo Bluetooth speaker options.
Not yet, our first stock only landed in Europe last week. I have tested it though and was quite pleased. Of course don't expect deep bass with these as they are never going to do thta, but clarity is good and the mid and high tones are represented well. For £15, I'm sure it's worth a punt too. Use it in bed and a holder as well.
it is blue and black if you put it on a white background and look at it through a potato camera
I'd never normally give a cheap bluetooth speaker a second look, however I love the concept of this one, being able to double up as a stand. Very cool idea, and for only £15?!
Does it also have a line in jack so I can be used with a non Bluetooth device?
Not sure if it'd be a good idea to plug yourself in, but you can plug it in to other devices via cable:
"Connection : Bluetooth or 3.5mm Stereo Cable"
