[RXP]Andy;27506972 said:Thanks for the confirmation, I will double check on my PSU tonight to see if I have the XP2 verison. If not i'll have a excuse to upgrade
Then you win either way - no matter what the answer will be!
[RXP]Andy;27509221 said:Good news! It looks like mines is a SS-860XP2, So ill should be ordering a Red and Black kit for my X99 build.
So will any of the SE kits fit then?
Do you have any plans for the xp1 series ?
Can't wait for mine to turn up, get my long awaited review up. Looking forward to it.
I don't think you should label them on the connector itself as it would not look good IMO, but maybe on the plastic packing holding each cable.
Ok, I'm all plugged in after a case transfer (woohoo!)
Before (case = Fractal Design R4) (its in a slight state of undress as I forgot to take a before picture...but ribbon cables, yuck!)
After (Phanteks Enthoo Luxe)
More room to work with in the Luxe, you're not getting a cable management pic though as I need to make some alterations in a few weeks with a few more additions.
Cablemods cables:
The Good
Packaging was of a very high quality so it made sense for the product to be likewise. And I was not disappointed.
Very flexible to work with and everything was the right length with some excess. So much better than Corsairs ribbons (Yes, I hate ribbon cables)
Colour is good and finish is fantastic. No problem with power supply either, just slotted straight in. I can't really add anything else as they speak for themselves.
The Bad
I would like to see cable combs come with this product, just the 24pin, 8 pin CPU and GFX would do and they are certainly cheap enough.
Cable marking would be handy (Corsair has PCI-E or CPU marked on theirs) as once again (I really don't know how I manage it) I put the wrong cable into the 8pin mobo slot and scratched my head as to why my system wouldn't boot. You'd think the double clip would give it away
Maybe a choice of cables too, I have a half a box left as I don't need them all and it seem a shame for them to go into storage.
The Ugly
That Beige Noctua fan. Noctua are fan-tastic at what they do and they are very distinct. This build will be watercooled as soon as I can make it happen though (next month).
Overall 9/10. Great product
(now where's my free stuff?)
^ That would be good. My PSU is hidden so if they were labelled that end I obviously wouldn't have a problem. Tags on the cable maybe. Its not a major thing though, just some people (me) get over-excited by new shiny stuff and jam it all together in their rush of euphoria and miss quite obvious details.
Like the build Razor, the white cables make a huge difference
ETA on p2 red & black restock and the cable combs you promised ?
Great. Didn't even think about colour options.
Green, Black or Clear? Decisions.......
Where and when can i get them and what will it cost me?
Review written. Just sorting some photos out. Will post tomorrow
