** New Product In Win D-Frame Mini ITX **
7 Feb 2011
Stoke on Toast
IN WIN D-Frame Mini Mini-ITX Case - Black @ £239.95 inc VAT
Continuing the iconic D-Frame aluminum pipe structure, In Win once again designed the most powerful, most forward-looking and ultra-portable mini-ITX gaming chassis. We’ve expanded the definition of mini, by creating an enclosure which can house powerful components and provide you nothing less than the ultimate gaming experience.
Iconic D-shaped Aluminum Pipe Framework
-Solid and rigid aluminum pipe structure
-Tinted tempered glass side panel
Incredibly Powerful with Compact Design
-Supports high-end graphiccard up to 340mm
-Supports PSU up to 220mm
Ultra-Portable and Flexible
-Revolutionary 6-dimentional positions
-Durable hand carry grip design
Precision Engineered to Detail
-Hand-crafted with precisely welded construction
-Shock-proof stands for excellent shock reduction
Excellent Thermal Solutions
-Open-frame structure allows excellent ventilation
-Supports water cooling radiator up to 240mm
Specifications:-
- Material: Aluminum Pipes
- Aluminum Metal Plate
- Tempered Glass
- Internal Drive Bay 3.5” or 2.5” x 3 2.5” x 2
- M/B Form Factor: Mini-ITX
- Power Supply: ATX12V, PSII and EPS (Up to 220mm)
- I/O Port: USB 3.0 x 2, HD Audio
- I/O Expansion Slots PCI-E Slot x 2
- Supports High-end Graphic Card (Length: up to 340mm,Height: up to 150mm)
- Thermal Solution Supports: 120mm Bottom Fan x 2, 240mm Liquid Cooling Radiator
- CPU Heatsink up to 165mm
- Dimension (HxWxD): 405 x 230 x 501mm (16” x 9” x 19.7”)
- Net Weight: 5.25 kg
- Gross Weight: 7.22 kg
Only £239.95 inc VAT.
ORDER NOW
IN WIN D-Frame Mini Mini-ITX Case - Red @ £239.99 inc VAT
Only £239.99 inc VAT.
ORDER NOW
IN WIN D-Frame Mini Mini-ITX Case - Orange @ £239.99 inc VAT
ORDER NOW
look cool like a generator but the price is lol worthy.
240 quid for basically a bit of pipe and a mobo tray.
The price is high but i think people forget just how amazing these frames are. If your looking for something unique and you have the cash why not.
Personally its not my cup of tea but I do think there is a market for them.
