**New Product Zowie EC1-A EC2-A**
7 Feb 2011
Stoke on Toast
Finally the anticipated Sensor update to the EC1 and EC2 has arrived so ffor those of us that prefer a slightly larger mouse can enjoy the benefits of the Successful Fk1 and FK2 mouse Sensor in a larger shape. You will also notice as with teh new mouse mats the Logo has been changed we didn't talk abotu this when it happened as we didn't want to confuse it till new mice started appearing with the logo on it. Like it or hate it the Logo doesn't change the fact the Mouse remains one of the best FPS mice on the market.
Stock should be with us by the 20th of Feb
Zowie EC1-A Gaming Mouse @ £49.99 inc VAT
In the highly competitive world of eSports, we are fortunate to see more and more exciting games. The outcome of a duel between the top players is often determined by a second - a second containing a player’s enthusiasm, persistence and dreams. They must play for victory while avoiding the slightest mishap.
ZOWIE GEAR upholds the spirit of endless pursuit of product quality and continuous understanding of a player's needs. Developing a stable product improves the performance of competitive players, fulfilling ZOWIE’s commitment to eSports and players. Under this philosophy players are able to choose different mouse shapes, sizes and surface coating with the same performance.
The Avago 3310 optical sensor has already been on the market for some time and many ZOWIE GEAR supporters suggested that this sensor should be used in the next ZOWIE mouse. Developing a new mouse with this sensor was not difficult. The difficult part was to make a new mouse that upholds ZOWIE standards for competitive gaming gear while maintaining the advantages of the sensor.
One key feature for ZOWIE is the low lift-off distance which is important for any serious gamers. After lots of repeated testing, the research and development team was successful, achieving the low lift-off distance for the new model (1.5~1.8mm). All gamers that are interested in this signature feature from ZOWIE will be able to enjoy it in the new ZOWIE EC1-A.
The new EC1-A and EC2-A series keeps the same shape and size from the original EC series and introduces the Avago 3310 sensor just like the FK series. After releasing mice with different surfaces, ZOWIE GEAR understood that most people prefer the coating used in the FK and EC eVo CL lines and, as such, the new EC line will also use this coating.
Features
- Ergonomic right-handed design
- Plug and play - no driver needed
- Perfect lift-off distance: Only 1.5 ~ 1.8 mm
- 24-step scroll wheel
- DPI ( Dots Per Inch ): 400 / 800 / 1600 / 3200
- Adjustable USB report rate 125 / 500 / 1000 Hz
- Connector: USB
- Buttons: 5
- Length of cable: 2m / 6.6 ft
- Operating system: Win2000/XP/VISTA/7/8
Only £49.99 inc VAT.
ORDER NOW
Zowie EC2-A Gaming Mouse @ £49.99 inc VAT
ORDER NOW
Also recently released was an updated mouse mate made from a harder material also baring the new logo
Zowie P-SR Gaming Mouse Pad @ £15.95 inc VAT
The new base of the G-TF Speed and CM Series is perfectly flat and good, but it's slightly harder in comparison to the traditional cloth mouse pad. We understand the need of gamers who prefer to use a cloth pad. After years of development and testing we have finally found the answer - a new ZOWIE GEAR rubber base was born and will be put to use in our new SR Series.
- The smooth and even texture offers a consistent and comfortable glide
- Newly designed rubber base offers increased stability on any surface
- 100% compatible with all types of mice
- Dimension: 355 x 315 x 3.5 mm / 14.0 x 12.4 x 0.14 inch
Only £15.95 inc VAT.
ORDER NOW
Zowie G-SR Gaming Mouse Pad @ £23.99 inc VAT
- Dimension: 480 x 400 x 3.5 mm / 18.9 x 15.7 x 0.14 inch
Only £23.99 inc VAT.
ORDER NOW
These look great to me. New logo is inoffensive but I don't understand it (curvy Zs don't work).
Do they still have the colour changing mousewheel LED for the DPI setting?
Bought one as soon as I saw it, Been waiting for this since my EVO CL failed, Got an FK1 to use temporarily until they put the 3310 into the EVO shape.
New logo is rubbish, it looks more like a 2 than a Z.
But who cares, what's the mouse like? It's time for another review guys...
I will most likely be buying one of these so I can do a review Allthough it is just an FK1 with an EC1 shell
So the review will be about how similar to a rival it is with none of the software features.
I have a Rival, Acceleration amount and IIRC angle snapping, Are they features because they should be turned off. Other than led colours the only features I see the software having is a larger amount of DPI/CPI steps and I guess the cloud syncing.
The FK1 does allow LOD adjustment (This EVO should too), Not sure if the Rival does.
angle snapping is something you absolutely do not want on at all.
as is acceleration.
highest polling rate also is something to consider.
Looks pretty nice. The larger one I'm guessing is over sized and the smaller of the two an average size?
Got to agree on the logo though, It does look more like a 2.
