** New products at OcUK Now In Stock Epiphany Acoustics DAC's and Headphone Amps**
7 Feb 2011
Stoke on Toast
As some of you will be aware that we've started stocking a variety of DAC and Headphone amps. With Headphones being planned to be added in the near future.
These items are an alternative to sound cards can be used on your laptop Desktop even Raspberry pi.
I've been using one of the EHP-O2D Dac headphone amps for the best part of a month now it's easy to use no drivers needed wonderful sound. an Uncomplicated and marked improvement to laptop and on board audio without having to take your PC apart.
Knowing some of you may have headphone amps and others may already have sound cards we also stock the Digital Analogue converter on it's own and a Portable Battery powered headphone amp suitable for powering All sorts of headphones when use din conjunction with MP3 Players, Smart Phones or Tablets.
Epiphany Acoustics EHP-O2Di Dac & Headphone Amplifier @ £179.99 inc VAT
The EHP-O2Di combines the award winning headphone amplification technology of the EHP-O2 and the critically acclaimed 24 Bit USB DAC from the E-DAC in one small desktop enclosure - perfect for your home head-fi needs as well as offering the functionality to slot into an exisiting home hi-fi set up.
Taking the bit perfect digital signal from USB or the analogue signal from your chosen source component, the EHP-O2Di offers premium quality and flexibility in a home environment.
The headphone amplifier section has been designed from the ground up to offer some of the best, if not the best, specifications and hi-fi functionality on the market today. This has been accomplished by months of development using top of the range audio testing equipment to fine tune and carefully select the most optimum design, layout and components. The specifications achieved speak for themselves. It is powered by the included AC adapter suitable for your region.
The DAC module is designed according to the same principles as the award EHP-O2 portable headphone amplifier and sports equally stunning performance.
This high end DAC is based on the TE7022L UAC1 engine and ES9023 24 bit DAC chip. It supports 16 bit and 24 bit at sample rates of 44.1kHz, 48kHz and 96kHz. The on-board filtered power supply ensures that noise is practically non-existent. The DAC is not clocked by the USB port/computer, instead using a high quality on board crystal controlled oscillator which further improves overall performance. The input signal and power is supplied via the USB input on the rear of the unit.
Features
USB digital input.
RCA analogue line out from DAC, allowing you to connect the DAC output to an external amplifier.
RCA analogue line in, allowing you to connect analogue sources to the headphone amplifier section.
Technical Specifications (Headphone Amplifier):
- THD @ 1kHz: 0.0017%
- Noise level (ref 400mV): -105dB
- Power output @ 33O : 641mW
- Crosstalk: 65dB
- Channel balance: 0.6dB
- Output impedance: 0.5 Ohms
- Dimensions (W x H x L): 108.5mm x 30mm x 82mm
- Gain: 1x and 5x
Technical Specifications (DAC):
- Distortion: <0.005%
- Dynamic range: >110dB A-Weighted
- Audio formats: 44.1kHz, 48kHz & 96kHz @ both 16 bit and 24 bit
- Interface: USB Audio Class 1
- Computer compatibility: Windows, Mac, Linux
- Line output: 2Vrms
Included Accesories
- AC Adapter
- 1m USB A to USB mini cable
- 1.2m mini jack interconnect
- 4 x self adhesive rubber feet
Only £179.99 inc VAT.
ORDER NOW
Epiphany Acoustics E-DAC 24 bit Miniature USB DAC @ £89.99 inc VAT
The E-DAC is Epiphany Acoustics’ offering of the ODAC as designed by NwAvGuy in its own stand alone, custom enclosure. As with the EHP-O2, the DAC has been designed to achieve truly remarkable specifications at an extremely attractive price. This, once again, has certainly been achieved.
The E-DAC is a stand alone USB digital-to-analogue converter which comes in a small form factor aluminium enclosure with custom front and rear panels. Input and power is supplied via the USB input on the front of the unit. There are two line level analogue outputs - via the 3.5mm mini jack socket on the front and the stereo RCA sockets on the rear of the unit. The E-DAC will take your computer audio to the next level and when coupled with the EHP-O2 provides an award winning audiophile experience far beyond their price level.
- See more at: http://epiphany-acoustics.co.uk/pro...24bit-miniature-usb-dac/#sthash.I7MHNR1k.dpuf
This high end DAC is based on the TE7022L UAC1 engine ES9023 24 bit DAC chip. It supports CD quality 16 bit and studio quality 24 bit at sample rates of 44.1kHz, 48kHz and 96kHz. The on-board filtered power supply ensures that noise is practically non-existent. The DAC is not clocked by the USB port/computer, instead using a high quality on board crystal controlled oscillator which further improves overall performance.
Features:-
- ES9023 DAC chip
- 16 bit and 24 bit
- 44.1kHz, 48kHz and 96kHz
- On-board filtered power supply
- On-board crystal controlled oscillator
- Works straight from USB
- 3.5mm and stereo RCA line outputs
Technical specifications:-
- Compatibility: Windows, Mac, Linux Line output: 2Vrms -
Only £89.99 inc VAT.
ORDER NOW
Epiphany Acoustics EHP-O2 Award Winning Portable Headphone Amplifier @ £79.99 inc VAT
Winner of Best Headphone Amplifier of the Year 2012 – Hi-Fi World Magazine
The Epiphany Acoustics EHP-O2 is a battery powered portable headphone amplifier which has been designed from the ground up by electronic engineer 'NwAvGuy' to offer some of the best, if not the best, specifications and hi-fi functionality on the market today. This has been accomplished by months of development using top of the range audio testing equipment to fine tune and carefully select the most optimum design, layout and components. The specifications achieved speak for themselves.
- High power output
- 2 x high capacity rechargeable batteries
- Highly optimised component selection and circuit design
- Ultra low output impedance
- In built power management circuity
- 1 x 3.5mm analogue input
- 1 x 3.5mm headphone output
- 1x and 5x gain settings
Technical Specifications:
- Crosstalk: 65dB
- Battery life: up to 11 hours
Included Accessories
- AC adapter
Only £79.99 inc VAT.
ORDER NOW
Awesome that OcUK are stocking the ODAC now - its got to be one of the best budget DACs under £500 ATM.
Plus good to see that you are supporting a British company too.
Out of interest what headphone brands are you going to stock??
I am trying to find a quality product from a supplier that will fit that price range but it's proving harder than you would think. Turns out this is all a bit of a niche product. ;)
For this money however it's a great product well built easy to transport plug and play no nonsense. With the addition of the Speaker Pass through it is a suitable alternative to a sound card.
