New Project - finished **Pics**
Finally finished my new watercooling rig :
Cooling Spec :
CPU Loop
18w Laing DDC Ultra pump
Thermochill PA 120.3
Thermochill 120.3 shroud
D-Tek Fusion CPU block
Danger Den 680i Chipset block
Danger Den Dual bay acrylic reservoir
8ft Danger Den Clearflex 60
8 x Danger Den High-flow barbs - 2x 3/8-1/2 barbs.
2 litres distilled
Pentosin G11 Coolant
PT-Nuke
Invisible UV-Blue dye
3 x Yate loon 120mm clear case fans (blue leds) - D12SL-12 controlled by :
Akasa Super flower fan controller.
GPU Loop
10w Laing DDC Pro (Blue impellor - moddable) pump.
HWlabs Black Ice GT Stealth 120.2
EK 8800GTX acrylic top
EK 150 multioption reservoir
6ft Danger Den Clearflex 60
8 x EK high flow barbs
1.5 litres distilled
Zerex super coolant
UV purple feser UV dye
2 x Yateloo 120mm clear case fans (blue leds) - D12SL-12 controlled by :
I'll post up some temps when I get it hooked up later.
Cooling Spec :
CPU Loop
2 litres distilled
PT-Nuke
GPU Loop
Zerex super coolant
