New PSU Advice
21 Jul 2004
Harrow, UK
I recently bought a EVGA 8800GTX, and I think my 500W Enermax Liberty is struggling with:
AMD Opteron 165 @ 2.7Ghz
4 x 500GB WD HDDs
Audigy Sound Card
DVD-RW Drive
4 120mm Fans
Here are the ones I was looking at:
Enermax Liberty 620W ELT620AWT ATX2.2 Modular SLI Compliant PSU - £93.99
Corsair HX 620W ATX2.2 Modular SLI Compliant PSU (CMPSU-620HXUK) - £88.11
Which one would you guys recommend, and should I be considering other ones?
corsair hx620, the hx range of psus have been great for a long time and its also cheaper too
a hx520 may be capable of running your rig, but if have the money to get the 620, i would recommend you do as it gives more headroom for upgrading
is your enermax still working perfectly fine without having to power the 8800GTX or other similar high demand parts?
if so maybe flog it in MM or keep it as a spare PSU
Yeah, it works perfectly... well until I added the 8800GTX a couple of days ago. I can't afford to keep it as a spare, so I think MM is the next step :(
