New PSU advice
5 Mar 2010
Hi
Currently looking for a new PSU. Spec as below.
i5 750 at 3.8ghz 1.232 core volts
2 sticks dd3 1600mhz
2 samsung f3 500 gb
Ati radeon 5750 (not clocked)
2 x 140mm yate loon
3 x 120mm yate loon
scythe kazemaster fan controller
I dont plan to do SLI etc but I would like a PSU to last 3 years plus
Do you think I could get by with this ? OCZ StealthXStream 2 500W Power Supply
Or is the 600watt more appropriate?
TIA
John
The 500w is more than enough. My rig (in siggy) pulls a max of 334w at the wall and even then only by running Prime and Furmark stablitiy test both at the same time. Normal gaming useage is 224-276w depending on the game.
