Hi all,
I am about to rebuild my PC around AM5/9800X3D. I want to upgrade my PSU at the same time. My present PSU is a Seasonic Focus GX Gold 850w.
I would like to go for a 1200w PSU (Gold or Platinum) so that I have overhead for the future.
Does it matter if the PSU is ATX 3.0 or 3.1? My understanding is that the 3.0 uses a 12VHPWR connector on the PSU side and the 3.1 has moved to a 12V-2x6 connector? Does it matter if the PSU has either or non of these connectors? At the moment, I am just using a 12VHPWR adapter that came with my GPU to connect to my PSU. I assume that future NVIDIA GPUs will use 12V-2x6 instead, and adapters will be available?
Any advice or recommendations on the PSU would be appreciated.
Thank you.
Thank you.
