- 1 Nov 2016
Hey dudes
Apologies for long post
Im looking to downgrade my current PSU which is a Superflower Leadex Platinum 1600W. Completely overkill for my current setup but i got it for a super deal from here, cheaper than lower wattage PSU's at the time. Anyway im after a PSU that's not going to be overkill but can handle the next gen stuff like Kaby Lake cpu and 2x 1080Ti's, full watercooling setup etc. Ive heard/seen around that EVGA have PSU's that are basically Superflower internals but with better support and longer warranty... if so which models are those? I ask this because i want to have custom cables made from CableMod, i would normally buy the OEM Superflower PSU but since they are fussy and don't support custom cables from cable mod im looking into other options instead.
Thanks for reading
Thanks for reading
