Hey all, hope everyone's well, just after a bit of advice...
Turned my PC off as usual the other night then the following day, attempted to turn it on but nothing. The Mobo was lit up and connected USB (light strip on the back of the desk). Literally took everything apart and upon sliding the dust filters out on the bottom of the case, there appeared to be some sort of cable shielding in tiny pieces which is unusual (directly underneath where the PSU fan is) and the PSU at times does make a noise when initial power goes to it when plugged in (also have a decent surge protector as an extension lead).
I checked all cables, hoovered out all the dust from fans, GPU etc and still no luck. I have a 'start', 'reset' and 'cmos' button on the mobo, pressed the 'cmos' button for a second and it sprang into action. Nearly booted up, fans on, hard drive into play then instantly powered down but powering back up presenting me with the screen to enter bios. Had a quick look through unable to spot anything unusual so exited whereby Windows booted as normal. Everything worked fine, had a game of DOOM Eternal which ran flawlessly for a while too. Complete shut down then the following day, same thing, would not boot unless I pressed the 'cmos' button on the mobo. The Bios is constantly showing the wrong date/time even when corrected (battery gone on the mobo?) and obviously the cable shielding found beneath the PSU leads me to believe it may be something to do with this?
I have not changed any hardware recently, overclocked or played about with anything else. Maybe a new software install here and there but surely that shouldn't cause anything such as this...
Any thoughts or advice would be much appreciated, full spec below. Thanks.
Intel Core i7-6700K 4.0GHz (Skylake) Socket LGA1151 Processor
Asus Maximus VIII Hero Intel Z170 (Socket 1151) DDR4 ATX Motherboard
Samsung 250GB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive
Seagate 1TB 7200RPM SATA 6Gb/s 64MB Cache HDD
OcUK 24x DVD±RW SATA ReWriter
MSI GeForce GTX 1070 "Founders Edition" 8192MB GDDR5 PCI-Express Graphics Card
Corsair RM Series RMi 850 '80+ Gold' 850W Modular Power Supply (CP-9020083-UK)
Microsoft Windows 10 64-Bit DVD - OEM (MS-KW9-00139)
Corsair Vengeance LPX 8GB (2x4GB) DDR4 PC4-25600C16 3200MHz Dual Channel
Phanteks Enthoo Luxe Full Tower Case
