new PSU with decent length on CPU power
10 Apr 2015
Hungerford, UK, Earth
hopefully ordering a gtx 970 today.. current spec below
Intel i7 920 2.6ghz overclocked to 3.5ghz
Gigabyte GA-EX58 ..motherboard
12gb Corsair Dominator triple channel 1600
MSI GTX 660ti 2gb
650w PSU
want a fully modular 650-750 psu, with decent length on the CPU power, my current maplin unbranded psu (was an emergency old one died) has a short cpu lead that i have to bring across the front of the motherboard, i want to tuck it neatly away behind the mb tray.. its a fractal define case, not sure model its no made now though but looks like R4
PS, i see a lot of talk about super flower, but only here, are they OCUK exclusive
YOUR BASKET
1 x EVGA SuperNova G2 750W '80 Plus Gold' Modular Power Supply £89.99
1 x SuperFlower Golden Green HX 750W "80 Plus Gold" Semi-Modular Power Supply - Black £76.99
Total : £176.58 (includes shipping : £8.00).
http://www.super-flower.com.tw/products_detail.php?class=2&sn=18&ID=116&lang=en
Fixed 1 cable > 20+4pins MB power connector (550mm)
1 cable > 8pins (4+4pins) ATX (650mm)
1 cable > 8pins EPS (650mm)
Modular 2 cables > 3 x SATA (500mm+130mm+130mm)
1 cable > 2 x SATA + 1 x 4pins Molex (500mm+130mm+130mm)
1 cable > 3 x 4pins Molex (500mm+130mm+130mm)
2 cables > 2 x 8pins (6+2pins) SLI (500mm+130mm)
  Total: 3 Fixed Cables[Sleeve] + 6 Modular Ribbon Cables
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story2&reid=380
Cabling - EVGA G2 750W
Type of Cable Length from PSU
Modular Cables
24 pin ATX connector 590mm
4+4 pin EPS/ATX12V 700mm
6+2 pin PCI-E 700mm
6+2 pin PCI-E 700mm
6+2 pin PCI-E 700mm
6+2 pin PCI-E 700mm
5.25" to 3.5" adapter 105mm
5.25"+5.25"+5.25"+5.25" 550+100+100+100mm
SATA+SATA+SATA 550+105+105mm
Unit Dimensions (L x W x H)
180mm x 150mm x 86mm
wow quick repsonse , tempted by the EVGA one.. thanks
ps how do you guys do "this is your basket"
